주요 콘텐츠로 건너뛰기
Acer Aspire 3003WLCi Battery Replacement
  1. Acer Aspire 3003WLCi Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Battery Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire 3003WLCi Battery Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire 3003WLCi Battery Replacement: 2 단계, 이미지 3개 중 3개
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3003WLCi Battery Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
결론
작성자
3다른 기여자 명과 함께
Tristin Viale
회원 가입일: 03/25/19
675 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 UMass Dartmouth, Team S2-G2, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G2
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 281
