주요 콘텐츠로 건너뛰기
Acer Aspire 3410 Screen Replacement
필요한 것
  1. Acer Aspire 3410 Screen Replacement, Unscrewing bottom lid: 1 단계, 이미지 2개 중 1개 Acer Aspire 3410 Screen Replacement, Unscrewing bottom lid: 1 단계, 이미지 2개 중 2개
    • Remove the battery
    • Turn the laptop so that the lid touches the table and unscrew the screws. There are 14 long ones and 2 short ones.
  2. Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: 2 단계, 이미지 3개 중 1개 Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: 2 단계, 이미지 3개 중 2개 Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: 2 단계, 이미지 3개 중 3개
    • Pop up the keyboard with a flat screw driver. Pay attention to the connector between the keyboard and the mother board.
    • Disconnect the keyboard from the motherboard by lifting the black part of the FPC connector.
    • Unscrew 8 screws.
  3. Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: 3 단계, 이미지 3개 중 1개 Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: 3 단계, 이미지 3개 중 2개 Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: 3 단계, 이미지 3개 중 3개
    • Disconnect the two flat cables with the FPC connectors as shown in the picture.
    • Detach the lid and disconnect the sound card reader (red/black cable pair).
  4. Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: 4 단계, 이미지 3개 중 1개 Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: 4 단계, 이미지 3개 중 2개 Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: 4 단계, 이미지 3개 중 3개
    • Unscrew the four screw in the screen lid.
    • Slide out the 4 lockers on the side of the screen. Be careful not to have the screen touch the motherboard as it might scratch the surface of the screen.
  5. Acer Aspire 3410 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the screen from the motherboard.
    • Connect the new screen and make sure to tape the cable to the screen (the connector should have a tape, if not, add one).
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
contact@kbl.netlib.re
회원 가입일: 09/27/18
416 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 986
