주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 Battery Replacement
  1. Acer Aspire 4520-5464 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Battery Replacement: 2 단계, 이미지 1/2 Acer Aspire 4520-5464 Battery Replacement: 2 단계, 이미지 2/2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Battery Replacement: 3 단계, 이미지 1/1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
결론
To reassemble your device, follow these instructions in reverse order using a new battery.
다른 2명이 해당 안내서를 완성하였습니다.
Byeloth Hermanson
회원 가입일: 09/21/17
285 평판
안내서 2개 작성하였습니다
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Washington State, Team S5-G117, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G117
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 439
