주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 Graphics Card Replacement
필요한 것
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Graphics Card Replacement: 2 단계, 이미지 2개 중 2개
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: 3 단계, 이미지 1개 중 1개
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 4 단계, 이미지 3개 중 1개 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 4 단계, 이미지 3개 중 2개 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 4 단계, 이미지 3개 중 3개
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: 6 단계, 이미지 1개 중 1개
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Graphics Card Replacement: 7 단계, 이미지 2개 중 2개
    • Lift up the heat sink line and remove the graphics card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hunter Gilcrease
회원 가입일: 09/21/17
382 평판
안내서 3개를 작성함
댓글 한 개
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 28
전체 시간: 2,574
