주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 Hard Drive Replacement
필요한 것
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: 2 단계, 이미지 1/2 Acer Aspire 4520-5464 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: 5 단계, 이미지 1/3 Acer Aspire 4520-5464 Hard Drive Replacement: 5 단계, 이미지 2/3 Acer Aspire 4520-5464 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the hard drive from the device.
결론
Hunter Gilcrease
회원 가입일: 09/21/17
367 평판
안내서 3개 작성하였습니다
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Washington State, Team S5-G117, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G117
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 828
