주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 RAM Replacement
필요한 것
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: 2 단계, 이미지 1/2 Acer Aspire 4520-5464 RAM Replacement: 2 단계, 이미지 2/2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: 3 단계, 이미지 1/1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: 4 단계, 이미지 1/2 Acer Aspire 4520-5464 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: 5 단계, 이미지 1/3 Acer Aspire 4520-5464 RAM Replacement: 5 단계, 이미지 2/3 Acer Aspire 4520-5464 RAM Replacement: 5 단계, 이미지 3/3
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ethan Woltersdorf
회원 가입일: 09/21/17
270 평판
안내서 2개 작성하였습니다
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Washington State, Team S5-G117, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G117
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
interesting good job
Maren Eras - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 1,240
