주요 콘텐츠로 건너뛰기
Acer Aspire 4741G-332G32Mn Screen Replacement
필요한 것
  1. Acer Aspire 4741G-332G32Mn Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Push the blue opening tool between the edge of the computer and the screen. Slide the tool around the perimeter of the screen.
  2. Acer Aspire 4741G-332G32Mn Screen Replacement: 2 단계, 이미지 1/1
    • Pop the two circle screw caps off and remove the two screws using a Phillips #0 screwdriver.
    • Remove the computer's frame.
  3. Acer Aspire 4741G-332G32Mn Screen Replacement: 3 단계, 이미지 1/2 Acer Aspire 4741G-332G32Mn Screen Replacement: 3 단계, 이미지 2/2
    • Remove the six screws from the four corners of the screen using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Screen Replacement: 4 단계, 이미지 1/1
    • Remove the screws from along the sides of the screen (two on each side) using the Phillips #0 screwdriver.
    • Remove the screen adapter from the screen.
    • Remove the screen from the rest of the laptop.
결론
kristen
회원 가입일: 03/21/19
364 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 UMass Dartmouth, Team S2-G6, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G6
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 727
