주요 콘텐츠로 건너뛰기
Acer Aspire 4743-6481 Keyboard Replacement
필요한 것
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire 4743-6481 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David Veres
회원 가입일: 02/22/17
140 평판
안내서 1개를 작성함
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 회원
USFT-LACY-S17S5G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 1,737
