주요 콘텐츠로 건너뛰기
Acer Aspire 4810TZ-4120 Fan Replacement
필요한 것
  1. Acer Aspire 4810TZ-4120 Fan Replacement, Fan: 1 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Lay the acer upside down
    • Use your screwdriver to unscrew all 19 two 5mm Phillips screws from the case
    • After unscrewing all the screws, lift the case upwards and remove it
  2. Acer Aspire 4810TZ-4120 Fan Replacement: 2 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Fan Replacement: 2 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Fan Replacement: 2 단계, 이미지 3/3
    • Go on the side of the computer
    • Use the plastic opening tool and press it in between the upper case and lover case
    • When the plastic tool is in between the cases, start going around the computer until both case are officially not connected
  3. Acer Aspire 4810TZ-4120 Fan Replacement: 3 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Fan Replacement: 3 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Fan Replacement: 3 단계, 이미지 3/3
    • Get a pair of tweezers
    • Start to detach the wires that are connected to the computer
    • Get a screwdriver and unscrew the screws that are circled in the picture
  4. Acer Aspire 4810TZ-4120 Fan Replacement: 4 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Fan Replacement: 4 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Fan Replacement: 4 단계, 이미지 3/3
    • Repeat Step 3 for detaching the rest of the tape
    • Disconnect all wires from the boards
  5. Acer Aspire 4810TZ-4120 Fan Replacement: 5 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Fan Replacement: 5 단계, 이미지 2/2
    • Lift up the upper case
    • Disconnect the power supply wiring (the black wire)
  6. Acer Aspire 4810TZ-4120 Fan Replacement: 6 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Fan Replacement: 6 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Fan Replacement: 6 단계, 이미지 3/3
    • Remove the three screws
    • Pull the boards upward
    • Flip the boards upside down
    • The screws and the board were removed so that the holes could be better shown
  7. Acer Aspire 4810TZ-4120 Fan Replacement: 7 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Fan Replacement: 7 단계, 이미지 2/2
    • Remove the four (4) screws that are holding the CPU's cover on
  8. Acer Aspire 4810TZ-4120 Fan Replacement: 8 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Fan Replacement: 8 단계, 이미지 2/2
    • Gently detached the wire that is connected to the computer
결론
Maria Saavedra
회원 가입일: 09/20/17
257 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 88
