주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show detailed steps to carefully disassemble the laptop, and replace the internal hard drive.
부품
지정된 부품이 없습니다.
  1. Lay the laptop upside down. Locate and unscrew the  seven phillips head screws.
    • Lay the laptop upside down.
    • Locate and unscrew the seven phillips head screws.
  2. Remove the cover panel from the laptop
    • Remove the cover panel from the laptop
  3. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out.
    • Remove the hard drive from the laptop by using a Spudger tool to pry it out.
결론
Antonio Kittrell
회원 가입일: 2017년 09월 20일
101 평판
안내서 1개 작성함
Yes, but how do you get the hard drive out of its carrier, for example in order to replace it with an SSD?
Philip Le Riche - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 282
