주요 콘텐츠로 건너뛰기
Acer Aspire 4810TZ-4120 Hard Drive Replacement
필요한 것
  1. Acer Aspire 4810TZ-4120 Hard Drive Replacement, Hard drive: 1 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Hard Drive Replacement, Hard drive: 1 단계, 이미지 2/2
    • Lay the laptop upside down.
    • Locate and unscrew the seven phillips head screws.
  2. Acer Aspire 4810TZ-4120 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the cover panel from the laptop
  3. Acer Aspire 4810TZ-4120 Hard Drive Replacement: 3 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Hard Drive Replacement: 3 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the hard drive from the laptop by using a Spudger tool to pry it out.
결론
Antonio Kittrell
회원 가입일: 09/20/17
101 평판
안내서 1개 작성함
댓글 한 개
Yes, but how do you get the hard drive out of its carrier, for example in order to replace it with an SSD?
Philip Le Riche - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 18
전체 시간: 513
