주요 콘텐츠로 건너뛰기
Acer Aspire 4810TZ-4120 Screen Replacement
필요한 것
  1. Acer Aspire 4810TZ-4120 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Unlock the battery by pushing and holding the lock button.
  2. Acer Aspire 4810TZ-4120 Screen Replacement: 2 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Screen Replacement: 2 단계, 이미지 2/2
    • While holding the lock button, pull out the battery
    • The battery is now ready to be replaced with a new one
  3. Acer Aspire 4810TZ-4120 Screen Replacement, Screen: 3 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Screen Replacement, Screen: 3 단계, 이미지 2/2
    • Locate and remove the four (4) pads using Angled Tweezers
  4. Acer Aspire 4810TZ-4120 Screen Replacement: 4 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the four screws that were under the pads
  5. Acer Aspire 4810TZ-4120 Screen Replacement: 5 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Screen Replacement: 5 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Screen Replacement: 5 단계, 이미지 3/3
    • Carefully pull the bevel (frame) off of the screen
  6. Acer Aspire 4810TZ-4120 Screen Replacement: 6 단계, 이미지 1/3 Acer Aspire 4810TZ-4120 Screen Replacement: 6 단계, 이미지 2/3 Acer Aspire 4810TZ-4120 Screen Replacement: 6 단계, 이미지 3/3
    • Locate the four screws that are holding the screen in place
    • Remove the screws
  7. Acer Aspire 4810TZ-4120 Screen Replacement: 7 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Screen Replacement: 7 단계, 이미지 2/2
    • Pull the screen out gently
    • Lay the screen down on the keyboard
  8. Acer Aspire 4810TZ-4120 Screen Replacement: 8 단계, 이미지 1/2 Acer Aspire 4810TZ-4120 Screen Replacement: 8 단계, 이미지 2/2
    • Locate the connector between the screen and the computer
    • Remove any tape
  9. Acer Aspire 4810TZ-4120 Screen Replacement: 9 단계, 이미지 1/1
    • Gently pull the connector off of the screen
    • The screen can now be replaced with a new one
결론
Sean Howard
회원 가입일: 09/20/17
208 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 467
