주요 콘텐츠로 건너뛰기
Acer Aspire 5 A515-43-R19L RAM Replacement
필요한 것
  1. Acer Aspire 5 A515-43-R19L RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Place your device with the top facing down.
    • Make sure the primary exhaust is facing away from you.
  2. Acer Aspire 5 A515-43-R19L RAM Replacement: 2 단계, 이미지 1/2 Acer Aspire 5 A515-43-R19L RAM Replacement: 2 단계, 이미지 2/2
    • Remove the nine screws from the bottom of the laptop using a Phillips #1 screwdriver.
  3. Acer Aspire 5 A515-43-R19L RAM Replacement: 3 단계, 이미지 1/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 3 단계, 이미지 2/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 3 단계, 이미지 3/3
    • Use a prying tool to separate the case from the laptop.
    • As you reach the exhausts and screen hinges, be especially careful. Too much force may cause unforeseen damage.
    • Potential device damage: Avoid pushing too far into the device during this process, as you may apply unnecessary force to the sensitive internals.
  4. Acer Aspire 5 A515-43-R19L RAM Replacement: 4 단계, 이미지 1/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 4 단계, 이미지 2/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 4 단계, 이미지 3/3
    • With any step working on the device's internals, keep direct contact with any components to a minimum. This is doubly true for your exposed skin.
    • While this step is not necessary, it is common practice to reduce the chances of things going wrong. (i.e "bricking" your device).
    • Use an opening tool to detach the battery connector from the motherboard.
  5. Acer Aspire 5 A515-43-R19L RAM Replacement: 5 단계, 이미지 1/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 5 단계, 이미지 2/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 5 단계, 이미지 3/3
    • You'll find RAM slots north of the battery connection point and to the right of the copper pieces.
    • Lightly grip and push both sides of the RAM housing in opposite directions until the RAM pops up from the slot at an angle.
    • Pull the RAM free from the slot.
  6. Acer Aspire 5 A515-43-R19L RAM Replacement: 6 단계, 이미지 1/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 6 단계, 이미지 2/3 Acer Aspire 5 A515-43-R19L RAM Replacement: 6 단계, 이미지 3/3
    • Align your RAM's DIMMs so the shorter side slots into the shorter space and the larger side slots into the larger space.
    • Insert the RAM at an angle.
    • Press down on the stick until the bearings on both sides click into place.
  7. Acer Aspire 5 A515-43-R19L RAM Replacement: 7 단계, 이미지 1/2 Acer Aspire 5 A515-43-R19L RAM Replacement: 7 단계, 이미지 2/2
    • Reconnect the battery to the motherboard.
  8. Acer Aspire 5 A515-43-R19L RAM Replacement: 8 단계, 이미지 1/2 Acer Aspire 5 A515-43-R19L RAM Replacement: 8 단계, 이미지 2/2
    • Place the shell back onto the laptop, clicking each corner and side into place.
    • Screw the shell back onto the laptop.
결승점
Troy Rana
회원 가입일: 10/25/23
175 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-18, Kershman Fall 2023 CSU Los Angeles, Team 4-18, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G18
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 68
전체 시간: 263
