주요 콘텐츠로 건너뛰기
Acer Aspire 5100 Keyboard Replacement
필요한 것
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Acer Aspire 5100 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: 2 단계, 이미지 1/3 Acer Aspire 5100 Keyboard Replacement: 2 단계, 이미지 2/3 Acer Aspire 5100 Keyboard Replacement: 2 단계, 이미지 3/3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: 3 단계, 이미지 1/1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Brad Rollinson
회원 가입일: 09/29/10
1,113 평판
안내서 7개 작성하였습니다
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 회원
CPSU-FORTE-F10S14G39
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 13,264
