이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Install a new keyboard for an Acer 5100 laptop.
필요한 것
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Locate the panel above the keyboard that has the power button on it.
Remove this panel by using a spudger to pry up the sides.
After you have used the spudger to release the tabs, lift up the panel.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
