주요 콘텐츠로 건너뛰기
Acer Aspire 5100 LCD Monitor Replacement
필요한 것
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire 5100 LCD Monitor Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire 5100 LCD Monitor Replacement: 2 단계, 이미지 3개 중 3개
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: 3 단계, 이미지 1개 중 1개
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: 4 단계, 이미지 1개 중 1개
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire 5100 LCD Monitor Replacement: 5 단계, 이미지 2개 중 2개
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire 5100 LCD Monitor Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: 7 단계, 이미지 1개 중 1개
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: 8 단계, 이미지 1개 중 1개
    • Lift up the monitor to detach it.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brad Rollinson
회원 가입일: 09/29/10
1,113 평판
안내서 7개를 작성함
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 회원
CPSU-FORTE-F10S14G39
5 회원들
안내서 10개를 작성함
1가이드 댓글
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 15,805
