주요 콘텐츠로 건너뛰기
Acer Aspire 5100 RAM Replacement
필요한 것
  1. Acer Aspire 5100 RAM Replacement, RAM: 1 단계, 이미지 1/2 Acer Aspire 5100 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: 2 단계, 이미지 1/3 Acer Aspire 5100 RAM Replacement: 2 단계, 이미지 2/3 Acer Aspire 5100 RAM Replacement: 2 단계, 이미지 3/3
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
결론
다른 7명이 해당 안내서를 완성하였습니다.
Brad Rollinson
회원 가입일: 09/29/10
1,113 평판
안내서 7개 작성하였습니다
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 회원
CPSU-FORTE-F10S14G39
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 16,277
