주요 콘텐츠로 건너뛰기
Acer Aspire 5253 Back Cover Panel Replacement
필요한 것
  1. Acer Aspire 5253 Back Cover Panel Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over.
  2. Acer Aspire 5253 Back Cover Panel Replacement: 2 단계, 이미지 1개 중 1개
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Back Cover Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Back Cover Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Back Cover Panel Replacement: 5 단계, 이미지 1개 중 1개
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Back Cover Panel Replacement, Back Cover Panel: 6 단계, 이미지 1개 중 1개
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Back Cover Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Back Cover Panel Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire 5253 Back Cover Panel Replacement: 8 단계, 이미지 2개 중 2개
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Back Cover Panel Replacement: 9 단계, 이미지 1개 중 1개
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Hanson
회원 가입일: 04/08/14
582 평판
안내서 2개를 작성함
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 회원
CPSU-REGAN-S14S8G11
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 2,806
