주요 콘텐츠로 건너뛰기
Acer Aspire 5253 Battery Replacement
  1. Acer Aspire 5253 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over.
  2. Acer Aspire 5253 Battery Replacement: 2 단계, 이미지 1/1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Battery Replacement: 3 단계, 이미지 1/1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Battery Replacement: 4 단계, 이미지 1/1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Battery Replacement: 5 단계, 이미지 1/1
    • You have successfully removed the battery. Congratulations!
결론
To reassemble your device, return battery pack to designated area. Push down until you hear a click, then lock the battery back into place.
다른 7명이 해당 안내서를 완성하였습니다.
Joseph Gagliano
회원 가입일: 04/08/14
573 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 회원
CPSU-REGAN-S14S8G11
4 회원들
안내서 15개 작성하였습니다
댓글 3개
I have just bought aa new battery but wont hold the charge
Paul MGreor - 답글
Just bought a new battery and still draining faat
Paul MGreor - 답글
My computer acer aspire 21-531 has a blank screen with a blue two line enter current password when I try to enter the password it does not take it we had reset my computer and got this. Please help
Melinda harbison - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 11,889
