주요 콘텐츠로 건너뛰기
소개
After you remove the back cover panel its not too difficult to slide the ram out of the laptop.
부품
지정된 부품이 없습니다.
  1. Turn the laptop over.
    • Turn the laptop over.
  2. "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. You have successfully removed the battery. Congratulations!
    • You have successfully removed the battery. Congratulations!
  6. Now, locate the two screws that hold the back cover panel onto the laptop.
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there. Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
  10. Once the cover panel is off, locate the hard drive.
    • Once the cover panel is off, locate the hard drive.
  11. Locate the two screws that are holding the hard drive in place. Locate the two screws that are holding the hard drive in place.
    • Locate the two screws that are holding the hard drive in place.
  12. Remove the two screws using a Phillips #00 screw driver.
    • Remove the two screws using a Phillips #00 screw driver.
  13. Carefully slide the hard drive in the opposite direction of where the screws are located until it dislocates.
    • Carefully slide the hard drive in the opposite direction of where the screws are located until it dislocates.
  14. Pull the hard drive out of its compartment.
    • Pull the hard drive out of its compartment.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Cynthia Barajas
회원 가입일: 2014년 04월 08일
1,754 평판
안내서 5개 작성하였습니다
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 회원
CPSU-REGAN-S14S8G11
4 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 33
전체 시간: 5,764
