주요 콘텐츠로 건너뛰기
Acer Aspire 5253 Optical Drive Replacement
필요한 것
  1. Acer Aspire 5253 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over.
  2. Acer Aspire 5253 Optical Drive Replacement: 2 단계, 이미지 1/1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Optical Drive Replacement: 5 단계, 이미지 1/1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Optical Drive Replacement, Optical Drive: 6 단계, 이미지 1/1
    • Turn the computer over and locate the screw that is in between the battery and cover panel as shown in the picture.
  7. Acer Aspire 5253 Optical Drive Replacement: 7 단계, 이미지 1/1
    • Remove the screw with a Phillips #00 screw driver.
    • The screw is 3/8" in length and has a 1/4" head.
  8. Acer Aspire 5253 Optical Drive Replacement: 8 단계, 이미지 1/1
    • Carefully pry the optical drive loose.
  9. Acer Aspire 5253 Optical Drive Replacement: 9 단계, 이미지 1/2 Acer Aspire 5253 Optical Drive Replacement: 9 단계, 이미지 2/2
    • Slowly remove the optical drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cynthia Barajas
회원 가입일: 04/08/14
2,195 평판
안내서 5개 작성하였습니다
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 회원
CPSU-REGAN-S14S8G11
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 6,759
