필요한 것
To mount the network card, we have to put it diagonally if it can not be broken.
When it is already on, it is only necessary to adjust the screw.
To connect the two cables we have to put it on their sites and press until one click.
To mount the processor, what we have to do is put it straight, if the pins break, it will no longer work.
When it is well placed, we only have to adjust the screw until it is well fixed.
To mount the heatsink, we have to take good care of it, and if the processor could not be reheated, it would be wrong.
When it is well put put the four screws to fix it.
Set the heatsink to the fan.
When it is already cleaned, we return the four screws to it so that it does not open.
Then we place it in its place on the motherboard and fix it.
We do not forget to connect the cable.
To place the RAM we have to be careful that it can also be broken as the network card
We have to put it diagonally so it does not break.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
