필요한 것
To mount the keyboard, place it on the chassis and press until it clicks.
To mount the network card, we have to put it diagonally if it can not be removed.
When it is already on, it is only necessary to adjust the screw.
To connect the two cables you must place them on their receptacles and press until they click in.
To mount the processor, make sure you put it in straight, because if the pins bend, it will no longer work.
When it is in, you only have to adjust the screw to secure it.
To mount the heatsink, we have to take good care of it, and if the processor could not be reheated, it would be wrong.
When it is well-seated replace the four screws to fix it.
Set the heatsink to the fan.
When it is clean, return the four screws to it so that it does not come apart.
Then, place it in its place on the motherboard and secure it.
Do not forget to connect the cable.
To place the RAM we have to be careful that it can also be broken as the network card.
We have to put it diagonally so it does not break.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
