주요 콘텐츠로 건너뛰기
Acer Aspire 5334-2581 Hard Drive Replacement
필요한 것
  1. Acer Aspire 5334-2581 Hard Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Hard Drive  Replacement: 2 단계, 이미지 1/1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Hard Drive  Replacement: 3 단계, 이미지 1/1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Hard Drive  Replacement: 4 단계, 이미지 1/1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Hard Drive  Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Remove the two screws that hold the hard drive cover.
    • Lift the cover up and set it aside.
  6. Acer Aspire 5334-2581 Hard Drive  Replacement: 6 단계, 이미지 1/1
    • Be very careful not to damage the hard drive when removing it because you might damage the data.
    • Slide the hard drive out of its seat.
결론
다른 2명이 해당 안내서를 완성하였습니다.
gilson teixeira
회원 가입일: 10/20/16
334 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 12
전체 시간: 404
