주요 콘텐츠로 건너뛰기
Acer Aspire 5334-2581 Keyboard Replacement
필요한 것
  1. Acer Aspire 5334-2581 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Keyboard Replacement: 2 단계, 이미지 1/1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Keyboard Replacement: 3 단계, 이미지 1/1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Keyboard Replacement: 4 단계, 이미지 1/1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 5 단계, 이미지 2/3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 5 단계, 이미지 3/3
    • The keyboard is held underneath a plastic cover. remove this cover with a spudger.
    • Using a spudger, apply it underneath the keyboard and lift it up.
  6. Acer Aspire 5334-2581 Keyboard Replacement: 6 단계, 이미지 1/2 Acer Aspire 5334-2581 Keyboard Replacement: 6 단계, 이미지 2/2
    • Disconnect the keyboard flex cable, and now you are ready to install a new keyboard.
    • Take extra care, and try not to break the the latch that holds the cable in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
gilson teixeira
회원 가입일: 10/20/16
334 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 704
