주요 콘텐츠로 건너뛰기
Acer Aspire 5336-2524 Motherboard Replacement
필요한 것
추천 문서
  1. Acer Aspire 5336-2524 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire 5336-2524 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip over the laptop.
    • Make sure the battery lock is pushed down so the red part is exposed.
    • Push the switch all the way to the side and that will push the battery up.
    • Remove the battery.
  2. Acer Aspire 5336-2524 Motherboard Replacement, DVD/CD Drive: 2 단계, 이미지 1개 중 1개
    • Remove the M2.5x8 screw using a Phillips #0 screwdriver.
  3. Acer Aspire 5336-2524 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the DVD/CD drive out of the laptop.
  4. Acer Aspire 5336-2524 Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Flip over the laptop and remove all eleven of the M2.5x8 screws on the bottom of the laptop with a Phillips #0 screwdriver.
    • Remove all four of the M2x3 screws with a Phillips #0 screwdriver.
  5. Acer Aspire 5336-2524 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pry open the lower door on the bottom of the laptop using the iFixit opening tool.
  6. Acer Aspire 5336-2524 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire 5336-2524 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Put slight pressure on the hard drive and slide it to the left.
    • Now pull the hard drive out.
  7. Acer Aspire 5336-2524 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire 5336-2524 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the M2x3 screw on the wireless card with a Phillips #0 screwdriver.
    • Remove the wireless card antennas by lifting straight up on the base of the connection.
    • Remove the battery underneath the wireless card.
    • Remove the RAM modules by pushing the springs on the side and lifting up.
  8. Acer Aspire 5336-2524 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire 5336-2524 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Open the laptop.
    • Wedge the spudger or iFixit opening tool between the side of the keyboard and the laptop and apply a slight amount of upward pressure.
    • Push in the latches at the top of the keyboard using the spudger to release that part of the keyboard, and start to lift up the keyboard more and more as you push in the latches.
    • Remove the ribbon cable that connects the keyboard to the motherboard by pushing the black latch downward and then pulling the cable out.
  9. Acer Aspire 5336-2524 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the eight M2.5x8 screws with a Phillips #0 screwdriver.
    • Remove the cables indicated by simply pulling them out.
    • Remove the cables by lifting up on the black latch and pulling the ribbon out.
  10. Acer Aspire 5336-2524 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use the iFixit opening tool to start to pry open the laptop case.
    • Flip over the laptop and open the screen.
    • Finish opening up the case.
  11. Acer Aspire 5336-2524 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the cable by lifting the black latch and pull the ribbon out.
    • Verify that the other cables are fully unplugged.
  12. Acer Aspire 5336-2524 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove M2.5x8 screw with a Phillips #0 screwdriver.
  13. Acer Aspire 5336-2524 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the motherboard up and unplug the fan.
  14. Acer Aspire 5336-2524 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Acer Aspire 5336-2524 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Acer Aspire 5336-2524 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Now replace the motherboard with a new one and follow the steps in reverse to assemble the laptop with the new motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Carlin Sullivan
회원 가입일: 10/30/19
695 평판
안내서 4개를 작성함
UMass Dartmouth, Team S1-G4, Valliere Fall 2019 UMass Dartmouth, Team S1-G4, Valliere Fall 2019 회원
UMASSD-VALLIERE-F19S1G4
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 20
전체 시간: 2,533
