주요 콘텐츠로 건너뛰기
Acer Aspire 5349-2592 Hard Drive Replacement
필요한 것
  1. Acer Aspire 5349-2592 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Hard Drive Replacement, Back plate: 5 단계, 이미지 1/1
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Remove the the pin strip.
  8. Acer Aspire 5349-2592 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove the two screws from the caddy using the Phillips #0 screwdriver.
  9. Acer Aspire 5349-2592 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Slide out the caddy.
  10. Acer Aspire 5349-2592 Hard Drive Replacement: 10 단계, 이미지 1/3 Acer Aspire 5349-2592 Hard Drive Replacement: 10 단계, 이미지 2/3 Acer Aspire 5349-2592 Hard Drive Replacement: 10 단계, 이미지 3/3
    • Slightly lift up the hard drive and pull it out from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Abderahmane Naidjate
회원 가입일: 04/03/19
547 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G3, Simcock Spring 2019 UMass Dartmouth, Team S1-G3, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 1,750
