주요 콘텐츠로 건너뛰기
Acer Aspire 5517-1127 Battery Replacement
  1. Acer Aspire 5517-1127 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the laptop so that it is upside down facing away from you. The battery is at the bottom.
  2. Acer Aspire 5517-1127 Battery Replacement: 2 단계, 이미지 1/1
    • The smaller switch is on the left. Move it to the unlock position.
  3. Acer Aspire 5517-1127 Battery Replacement: 3 단계, 이미지 1/1
    • Once unlocked, move the larger switch on the right to the left to release the battery.
  4. Acer Aspire 5517-1127 Battery Replacement: 4 단계, 이미지 1/1
    • When the switch is moved to the left, the battery will pop up and become removable.
결론
Christopher Abrams
회원 가입일: 02/02/17
101 평판
안내서 1개 작성함
USF Tampa, Team 17-1, Blackwell Spring 2017 USF Tampa, Team 17-1, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 605
