주요 콘텐츠로 건너뛰기
Acer Aspire 5517-1127 Hard Drive Replacement
필요한 것
  1. Acer Aspire 5517-1127 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Orient the laptop so that it is upside down facing away from you. The hard drive panel is on the right.
    • The two screws are at the top of the panel.
  2. Acer Aspire 5517-1127 Hard Drive Replacement: 2 단계, 이미지 1/2 Acer Aspire 5517-1127 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Using a Phillips screwdriver (PH1), unscrew each screw from the panel.
    • Pull the panel away from the device as shown.
  3. Acer Aspire 5517-1127 Hard Drive Replacement: 3 단계, 이미지 1/2 Acer Aspire 5517-1127 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Push the hard drive out of its housing as shown.
  4. Acer Aspire 5517-1127 Hard Drive Replacement: 4 단계, 이미지 1/1
    • The hard drive is now removed.
결론
Christopher Newkirk
회원 가입일: 02/02/17
509 평판
안내서 4개 작성하였습니다
USF Tampa, Team 17-1, Blackwell Spring 2017 USF Tampa, Team 17-1, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 938
