주요 콘텐츠로 건너뛰기
Acer Aspire 5517-1127 RAM Replacement
필요한 것
  1. Acer Aspire 5517-1127 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Orient the device so that it is upside down facing towards you. The ram panel is in the middle of the device.
    • The screw is at the bottom of the panel.
  2. Acer Aspire 5517-1127 RAM Replacement: 2 단계, 이미지 1/2 Acer Aspire 5517-1127 RAM Replacement: 2 단계, 이미지 2/2
    • Using a Phillips screwdriver (PH1), unscrew the screw from the panel.
    • Pull the panel away from the device as shown.
  3. Acer Aspire 5517-1127 RAM Replacement: 3 단계, 이미지 1/1
    • The two tabs are at the top and bottom of the case as shown.
  4. Acer Aspire 5517-1127 RAM Replacement: 4 단계, 이미지 1/2 Acer Aspire 5517-1127 RAM Replacement: 4 단계, 이미지 2/2
    • Using two fingers, push the tabs inward to release the RAM from its casing.
    • Pull the RAM towards you to remove it.
  5. Acer Aspire 5517-1127 RAM Replacement: 5 단계, 이미지 1/1
    • The RAM is now removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Newkirk
회원 가입일: 02/02/17
509 평판
안내서 4개 작성하였습니다
USF Tampa, Team 17-1, Blackwell Spring 2017 USF Tampa, Team 17-1, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 404
