주요 콘텐츠로 건너뛰기
Acer Aspire 5734z-4836 Keyboard Replacement
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: 3 단계, 이미지 1/2 Acer Aspire 5734z-4836 Keyboard Replacement: 3 단계, 이미지 2/2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: 5 단계, 이미지 1/2 Acer Aspire 5734z-4836 Keyboard Replacement: 5 단계, 이미지 2/2
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: 6 단계, 이미지 1/3 Acer Aspire 5734z-4836 Keyboard Replacement: 6 단계, 이미지 2/3 Acer Aspire 5734z-4836 Keyboard Replacement: 6 단계, 이미지 3/3
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Holly Steininger
회원 가입일: 09/12/16
258 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,472
