주요 콘텐츠로 건너뛰기
Acer Aspire 5734z-4836 Screen Replacement
필요한 것
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: 2 단계, 이미지 1/1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: 3 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 3 단계, 이미지 2/2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: 4 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: 5 단계, 이미지 1/1
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: 6 단계, 이미지 1/1
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: 7 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 7 단계, 이미지 2/2
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: 8 단계, 이미지 1/1
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: 9 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 9 단계, 이미지 2/2
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: 10 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 10 단계, 이미지 2/2
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: 11 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 11 단계, 이미지 2/2
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: 12 단계, 이미지 1/3 Acer Aspire 5734z-4836 Screen Replacement: 12 단계, 이미지 2/3 Acer Aspire 5734z-4836 Screen Replacement: 12 단계, 이미지 3/3
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: 13 단계, 이미지 1/2 Acer Aspire 5734z-4836 Screen Replacement: 13 단계, 이미지 2/2
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Susan Cao
회원 가입일: 09/12/16
121 평판
안내서 1개 작성함
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 871
