주요 콘텐츠로 건너뛰기
Acer Aspire 5740-5780 Hard Drive Replacement
필요한 것
  1. 주의: 1-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 1 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 1 단계, 이미지 2개 중 2개
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: 8 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: 8 단계, 이미지 2개 중 2개
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire 5740-5780 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  10. Acer Aspire 5740-5780 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
    • Remove the one M2 x L4 screw that secures the hard drive in place.
    • Screw not shown in picture.
  11. Acer Aspire 5740-5780 Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Using an opening tool or your hands, slide the hard drive out of its connector.
  12. Acer Aspire 5740-5780 Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the hard drive out of the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dwyer Deighan
회원 가입일: 03/25/18
358 평판
안내서 3개를 작성함
UMass Dartmouth, Team S3-G6, Peak Spring 2018 UMass Dartmouth, Team S3-G6, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G6
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,633
