주요 콘텐츠로 건너뛰기
Acer Aspire 5741-5698 WIFI Chipset Replacement
필요한 것
  1. Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: 1 단계, 이미지 1/3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: 1 단계, 이미지 2/3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: 1 단계, 이미지 3/3
    • Begin on the back side of your laptop, locate these two screws then remove them with the JIS #0 driver bit.
  2. Acer Aspire 5741-5698 WIFI Chipset Replacement: 2 단계, 이미지 1/2 Acer Aspire 5741-5698 WIFI Chipset Replacement: 2 단계, 이미지 2/2
    • Once screws are removed you can pry up the panel to reveal some of your computers components.
  3. Acer Aspire 5741-5698 WIFI Chipset Replacement: 3 단계, 이미지 1/1
    • Locate your computers WIFI chip; it will have black and white wires attached to it.
  4. Acer Aspire 5741-5698 WIFI Chipset Replacement: 4 단계, 이미지 1/3 Acer Aspire 5741-5698 WIFI Chipset Replacement: 4 단계, 이미지 2/3 Acer Aspire 5741-5698 WIFI Chipset Replacement: 4 단계, 이미지 3/3
    • Using your fingers or a spudger, remove the black and white cables from the chip, at the connector.
  5. Acer Aspire 5741-5698 WIFI Chipset Replacement: 5 단계, 이미지 1/2 Acer Aspire 5741-5698 WIFI Chipset Replacement: 5 단계, 이미지 2/2
    • Using the same JIS#0 screw driver remove the single small 1/4 inch long screw.
  6. Acer Aspire 5741-5698 WIFI Chipset Replacement: 6 단계, 이미지 1/3 Acer Aspire 5741-5698 WIFI Chipset Replacement: 6 단계, 이미지 2/3 Acer Aspire 5741-5698 WIFI Chipset Replacement: 6 단계, 이미지 3/3
    • Now that the chip is released just gently remove it from its connector seat.
결론
Alex Imbery
회원 가입일: 01/24/19
133 평판
안내서 1개 작성함
Cal Poly, Team S18-G6, White Winter 2019 Cal Poly, Team S18-G6, White Winter 2019 회원
CPSU-WHITE-W19S18G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 584
