주요 콘텐츠로 건너뛰기
Acer Aspire 5742 Hard Drive Removal
필요한 것
  1. Acer Aspire 5742 Hard Drive Removal, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire 5742 Hard Drive Removal, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire 5742 Hard Drive Removal, Battery: 1 단계, 이미지 3개 중 3개
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: 2 단계, 이미지 3개 중 1개 Acer Aspire 5742 Hard Drive Removal, Cover Panel: 2 단계, 이미지 3개 중 2개 Acer Aspire 5742 Hard Drive Removal, Cover Panel: 2 단계, 이미지 3개 중 3개
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: 3 단계, 이미지 3개 중 1개 Acer Aspire 5742 Hard Drive Removal: 3 단계, 이미지 3개 중 2개 Acer Aspire 5742 Hard Drive Removal: 3 단계, 이미지 3개 중 3개
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: 4 단계, 이미지 3개 중 1개 Acer Aspire 5742 Hard Drive Removal, Hard drive: 4 단계, 이미지 3개 중 2개 Acer Aspire 5742 Hard Drive Removal, Hard drive: 4 단계, 이미지 3개 중 3개
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Skylar MacDonald
회원 가입일: 12/04/11
1,991 평판
안내서 5개를 작성함
댓글 4개
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - 답글
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - 답글
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 57
전체 시간: 45,827
