주요 콘텐츠로 건너뛰기
Acer Aspire 5742 Hard drive Replacement
필요한 것
  1. Acer Aspire 5742 Hard drive Replacement, Battery: 1 단계, 이미지 1/3 Acer Aspire 5742 Hard drive Replacement, Battery: 1 단계, 이미지 2/3 Acer Aspire 5742 Hard drive Replacement, Battery: 1 단계, 이미지 3/3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard drive Replacement, Cover Panel: 2 단계, 이미지 1/3 Acer Aspire 5742 Hard drive Replacement, Cover Panel: 2 단계, 이미지 2/3 Acer Aspire 5742 Hard drive Replacement, Cover Panel: 2 단계, 이미지 3/3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard drive Replacement: 3 단계, 이미지 1/3 Acer Aspire 5742 Hard drive Replacement: 3 단계, 이미지 2/3 Acer Aspire 5742 Hard drive Replacement: 3 단계, 이미지 3/3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard drive Replacement, Hard drive: 4 단계, 이미지 1/3 Acer Aspire 5742 Hard drive Replacement, Hard drive: 4 단계, 이미지 2/3 Acer Aspire 5742 Hard drive Replacement, Hard drive: 4 단계, 이미지 3/3
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
  5. Acer Aspire 5742 Hard drive Replacement, Drive bracket screws: 5 단계, 이미지 1/3 Acer Aspire 5742 Hard drive Replacement, Drive bracket screws: 5 단계, 이미지 2/3 Acer Aspire 5742 Hard drive Replacement, Drive bracket screws: 5 단계, 이미지 3/3
    • There is a small metal bracket on either side of the hard drive, with two small silver-coloured Phillips #00 screws securing the bracket to the drive on each side.
    • Unscrew the 2 screws on each side.
  6. Acer Aspire 5742 Hard drive Replacement, Drive brackets: 6 단계, 이미지 1/2 Acer Aspire 5742 Hard drive Replacement, Drive brackets: 6 단계, 이미지 2/2
    • When installing a replacement hard drive (or SSD), take care to attach the brackets to the drive the same way round as they were on the old drive otherwise the SATA connector won't mate.
    • Replace the 4 screws securing the brackets.
    • Replace the drive in the laptop and slide it into position, ensuring that the SATA connector is fully mated.
    • Replace the retaining screw holding the drive in position. Take care to insert it into the correct hole otherwise it will be impossible to insert the cover screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Philip Le Riche
회원 가입일: 02/18/14
30,089 평판
안내서 47개 작성하였습니다
Restart Project Restart Project 회원
Community
19 회원들
안내서 519개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 1,071
