주요 콘텐츠로 건너뛰기
Acer Aspire 5742 LCD Panel Replacement
필요한 것
  1. Acer Aspire 5742 LCD Panel Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire 5742 LCD Panel Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire 5742 LCD Panel Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 LCD Panel Replacement, Screen bezel screws: 2 단계, 이미지 1개 중 1개
    • Open the laptop lid as far as it will go. Using a small craft knife or similar, remove the two black adhesive screw covers on either side of the screen at the bottom, by inserting the tip of the blade under the edge of the cover.
    • Remove the 2 screws now revealed.
  3. Acer Aspire 5742 LCD Panel Replacement, Removing the screen bezel: 3 단계, 이미지 1개 중 1개
    • Separate the bezel around the screen by using a jimmy or similar tool to release the clips holding it in place. Work around both sides and the top. Finally, turn the laptop on its side in order to work along the bottom. You should now be able to lift off the bezel.
  4. Acer Aspire 5742 LCD Panel Replacement, Removing the LCD panel: 4 단계, 이미지 1개 중 1개
    • Remove 2 screws from the bottom of the LCD panel.
    • At the top of the LCD panel, remove the 2 screws furthest from the corners. Support the panel as you remove these screws.
    • Very gently angle the LCD panel forwards and lay it face down.
  5. Acer Aspire 5742 LCD Panel Replacement, Disconnecting the video cable: 5 단계, 이미지 1개 중 1개
    • Gently lift the transparent adhesive film covering the video connector on the back of the LCD panel, and disconnect the connector.
    • You can now completely remove the LCD panel.
결론
작성자
2다른 기여자 명과 함께
Philip Le Riche
회원 가입일: 02/18/14
31,561 평판
안내서 47개를 작성함
Restart Project Restart Project 회원
Local Repair Groups
25 회원들
안내서 375개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 34
전체 시간: 1,682
