소개
Upgrade your RAM for a noticeable increase in speed.
필요한 것
Move the battery catch to the "unlocked" position.
Pull back the second spring-loaded battery catch until the battery pops up.
Remove the battery.
Turn the notebook around to face you.
There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
note to add: it only supports 8gb (2x4gb) max
Hi, not sure if this is the right place to post this troubleshooting request.
I’ve re-seated the original 4GB memory and added a further 4GB into the additional slot on my acer Aspire 5742 laptop. When I turn it on, the machine shows the initial ACER splash screen with the ‘Press <F2> to enter Setup.’ message in the bottom left-hand corner and the hard drive briefly whirls before the laptop powers down. It then powers back up and continually loops this cycle until I remove the power sources (mains and battery). When I press <F2>, I get 4 (four) short, quick beeps - which I think is telling me to re-seat the RAM. I have re-seated the RAM a handful of times without any progress in the reboot.
Any pointers please as to where I am going wrong or what to try next?
