주요 콘텐츠로 건너뛰기
Acer Aspire 5749 Fan/HeatSink Replacement
필요한 것
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 1 단계, 이미지 3개 중 1개 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 1 단계, 이미지 3개 중 2개 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 1 단계, 이미지 3개 중 3개
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire 5749 Fan/HeatSink Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire 5749 Fan/HeatSink Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire 5749 Fan/HeatSink Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire 5749 Fan/HeatSink Replacement: 3 단계, 이미지 3개 중 3개
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
JeanChristophe
회원 가입일: 11/19/10
523 평판
안내서 3개를 작성함
댓글 5개
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - 답글
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - 답글
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - 답글
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 37
전체 시간: 7,852
