주요 콘텐츠로 건너뛰기
Acer Aspire 5750-6667 Memory Replacement
필요한 것
  1. Acer Aspire 5750-6667 Memory Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire 5750-6667 Memory Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Memory Replacement: 2 단계, 이미지 1/3 Acer Aspire 5750-6667 Memory Replacement: 2 단계, 이미지 2/3 Acer Aspire 5750-6667 Memory Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 3 단계, 이미지 1/3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 3 단계, 이미지 2/3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 3 단계, 이미지 3/3
    • Flip the laptop over and locate the bottom access panel. It is opposite the battery.
    • Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
  4. Acer Aspire 5750-6667 Memory Replacement: 4 단계, 이미지 1/3 Acer Aspire 5750-6667 Memory Replacement: 4 단계, 이미지 2/3 Acer Aspire 5750-6667 Memory Replacement: 4 단계, 이미지 3/3
    • Use the blue plastic opening tool to lift the panel away from the laptop.
  5. Acer Aspire 5750-6667 Memory Replacement, RAM: 5 단계, 이미지 1/3 Acer Aspire 5750-6667 Memory Replacement, RAM: 5 단계, 이미지 2/3 Acer Aspire 5750-6667 Memory Replacement, RAM: 5 단계, 이미지 3/3
    • Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
    • Using your thumbs, push the brackets away from the RAM . It should pop up when released.
    • You can now gently pull the top RAM out of the laptop.
  6. Acer Aspire 5750-6667 Memory Replacement: 6 단계, 이미지 1/3 Acer Aspire 5750-6667 Memory Replacement: 6 단계, 이미지 2/3 Acer Aspire 5750-6667 Memory Replacement: 6 단계, 이미지 3/3
    • Locate the second pair of metal clasps holding the bottom RAM in place.
    • Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
    • You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea Taylor
회원 가입일: 01/18/17
383 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 889
