주요 콘텐츠로 건너뛰기
Acer Aspire 5750-6677 Motherboard Replacement
필요한 것
  1. Acer Aspire 5750-6677 Motherboard Replacement, Battery Replacement: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire 5750-6677 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the tab and lift up to remove the hard drive.
  8. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Start by flipping the device over to expose the screws.
    • Remove ten screws with the Phillips #0 screwdriver.
  9. Acer Aspire 5750-6677 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the four screws found under the battery.
  10. Acer Aspire 5750-6677 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire 5750-6677 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Flip the laptop back around so the Acer logo is facing upwards.
    • Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
  11. Acer Aspire 5750-6677 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove six screws.
    • Pull the top off of the keyboard to expose the motherboard.
  12. Acer Aspire 5750-6677 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Acer Aspire 5750-6677 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Acer Aspire 5750-6677 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the seven screws using the Phillips #0 screwdriver.
    • Detach any wires or cables that are attached to the motherboard.
    • Remove the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Dean Smith
회원 가입일: 11/01/19
222 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G3, Valliere Fall 2019 UMass Dartmouth, Team S1-G3, Valliere Fall 2019 회원
UMASSD-VALLIERE-F19S1G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 41
전체 시간: 2,375
