주요 콘텐츠로 건너뛰기
Acer Aspire 6530-6522 Power Board Replacement
필요한 것
  1. Acer Aspire 6530-6522 Power Board Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Power Board Replacement: 2 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement: 2 단계, 이미지 2/2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Power Board Replacement: 3 단계, 이미지 1/3 Acer Aspire 6530-6522 Power Board Replacement: 3 단계, 이미지 2/3 Acer Aspire 6530-6522 Power Board Replacement: 3 단계, 이미지 3/3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Power Board Replacement: 4 단계, 이미지 1/3 Acer Aspire 6530-6522 Power Board Replacement: 4 단계, 이미지 2/3 Acer Aspire 6530-6522 Power Board Replacement: 4 단계, 이미지 3/3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Power Board Replacement, Power Board: 5 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement, Power Board: 5 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the ten 7mm screws in the bottom of the device that are holding the top panel.
    • Turn the device over and open it.
  6. Acer Aspire 6530-6522 Power Board Replacement: 6 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement: 6 단계, 이미지 2/2
    • Lift the top panel up from the back, turning it over forward.
  7. Acer Aspire 6530-6522 Power Board Replacement: 7 단계, 이미지 1/1
    • Lift the latch locking the cable.
    • Pull the cable free.
  8. Acer Aspire 6530-6522 Power Board Replacement: 8 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Pull the cable towards you to unplug it. Use tweezers if necessary.
  9. Acer Aspire 6530-6522 Power Board Replacement: 9 단계, 이미지 1/2 Acer Aspire 6530-6522 Power Board Replacement: 9 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the three 3mm screws from the power board.
    • Lift power board to remove it.
결론
William Michaud
회원 가입일: 03/20/18
343 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S5-G6, Peak Spring 2018 UMass Dartmouth, Team S5-G6, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 262
