소개
This guide will how you how to remove the power board under the power button on your Acer Aspire 6530-6522. You will need to do this if it becomes faulty or gets damaged.
필요한 것
Make sure the device is unplugged and completely powered down.
Turn the device over.
Using the Phillips #1 screwdriver, remove the ten 7mm screws in the bottom of the device that are holding the top panel.
Turn the device over and open it.
거의 끝나갑니다!
결론
