소개
This guide will show you how to remove the secondary hard drive. You will need to do this if the drive has become faulty and you have a new one, or if you want to use it in another device.
필요한 것
Make sure the device is unplugged and completely powered down.
Turn the device over.
While looking at the bottom of the device upside down from the front, the secondary hard drive is in the near, left corner.
Using a Phillips #1 screwdriver, remove the two 7mm screws on the right side of the cover.
다른 한 분이 해당 안내서를 완성하였습니다.
