주요 콘텐츠로 건너뛰기
Acer Aspire 7736Z-4809 CPU Fan Replacement
필요한 것
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 1 단계, 이미지 1개 중 1개
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 CPU Fan Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 CPU Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 6 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 6 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 CPU Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 CPU Fan Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 CPU Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Install the modified or new cooling fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Pnithan Jantarakolica
회원 가입일: 09/22/16
1,153 평판
안내서 10개를 작성함
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G4
5 회원들
안내서 10개를 작성함
댓글 한 개
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 26
전체 시간: 944
