주요 콘텐츠로 건너뛰기
Acer Aspire 7736Z-4809 Keyboard Replacement
필요한 것
  1. Acer Aspire 7736Z-4809 Keyboard Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 1 단계, 이미지 1개 중 1개
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
  4. Acer Aspire 7736Z-4809 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Orient the laptop so that the hinges between the LCD module and the laptop's bottom base are visible.
    • Use the plastic opening tools to separate the speaker panel from the laptop.
  5. Acer Aspire 7736Z-4809 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Flip over the LCD module of the laptop.
    • Insert the opening tool into the crack between the panel and the frame at either end. Slide the opening tool across the line. Reinsert the opening tool into the crack and apply leverage until the frame releases.
    • Repeat this step with the other side of the laptop.
  6. Acer Aspire 7736Z-4809 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Gently hold the speaker panel by the sides and pull upwards to release the panel.
  7. Acer Aspire 7736Z-4809 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use the flat end of the medium sized metal spudger tool to release the two tabs at the top of the keyboard.
    • Do not remove the keyboard yet.
  8. Acer Aspire 7736Z-4809 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Insert a finger into the opening above the F11 key and pry the keyboard until it is released from the casing.
  9. Acer Aspire 7736Z-4809 Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Gently raise the keyboard with your hands.
  10. Acer Aspire 7736Z-4809 Keyboard Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Keyboard Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Lift the black latch upwards to release the ZIF connector.
  11. Acer Aspire 7736Z-4809 Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the keyboard from the keyboard slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Pnithan Jantarakolica
회원 가입일: 09/22/16
1,153 평판
안내서 10개를 작성함
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G4
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,240
