주요 콘텐츠로 건너뛰기
Acer Aspire 7736Z-4809 Wireless Module Replacement
필요한 것
  1. Acer Aspire 7736Z-4809 Wireless Module Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 1 단계, 이미지 1/1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Wireless Module Replacement: 2 단계, 이미지 1/1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: 3 단계, 이미지 1/2 Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: 3 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 1/3 Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 2/3 Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 3/3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Wireless Module Replacement: 5 단계, 이미지 1/1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 1/3 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 2/3 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the white antenna of the wireless module.
    • Use tweezers if you do not prefer using hands.
  7. Acer Aspire 7736Z-4809 Wireless Module Replacement: 7 단계, 이미지 1/2 Acer Aspire 7736Z-4809 Wireless Module Replacement: 7 단계, 이미지 2/2
    • Remove the black antenna of the wireless module.
  8. Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 1/3 Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 2/3 Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the two 4.8mm Phillips #1 screws.
  9. Acer Aspire 7736Z-4809 Wireless Module Replacement: 9 단계, 이미지 1/2 Acer Aspire 7736Z-4809 Wireless Module Replacement: 9 단계, 이미지 2/2
    • Remove the wireless module from the laptop.
결론
Pnithan Jantarakolica
회원 가입일: 09/22/16
1,153 평판
안내서 10개 작성하였습니다
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 326
