주요 콘텐츠로 건너뛰기
Acer Aspire 7736Z-4809 Wireless Module Replacement
필요한 것
  1. Acer Aspire 7736Z-4809 Wireless Module Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 1 단계, 이미지 1개 중 1개
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Wireless Module Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Wireless Module Replacement: 5 단계, 이미지 1개 중 1개
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the white antenna of the wireless module.
    • Use tweezers if you do not prefer using hands.
  7. Acer Aspire 7736Z-4809 Wireless Module Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the black antenna of the wireless module.
  8. Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 8 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the two 4.8mm Phillips #1 screws.
  9. Acer Aspire 7736Z-4809 Wireless Module Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire 7736Z-4809 Wireless Module Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the wireless module from the laptop.
결론
작성자
5다른 기여자 명과 함께
Pnithan Jantarakolica
회원 가입일: 09/22/16
1,153 평판
안내서 10개를 작성함
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G4
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 486
