주요 콘텐츠로 건너뛰기
Acer Aspire 7741Z-4643 RAMReplacement
필요한 것
  1. Acer Aspire 7741Z-4643 RAMReplacement, RAM: 1 단계, 이미지 1/3 Acer Aspire 7741Z-4643 RAMReplacement, RAM: 1 단계, 이미지 2/3 Acer Aspire 7741Z-4643 RAMReplacement, RAM: 1 단계, 이미지 3/3
    • Begin with the bottom of the laptop facing up.
    • With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
    • Lift the panel at the top and pull towards you to remove it from the laptop.
  2. Acer Aspire 7741Z-4643 RAMReplacement: 2 단계, 이미지 1/3 Acer Aspire 7741Z-4643 RAMReplacement: 2 단계, 이미지 2/3 Acer Aspire 7741Z-4643 RAMReplacement: 2 단계, 이미지 3/3
    • The memory should be to the right, after you have removed the bottom panel.
    • Towards the bottom of the memory card, push outwards on the two small silver levers to release the memory card.
    • Pull the memory card out towards you to remove it.
결론
Amy Endo
회원 가입일: 10/22/18
186 평판
안내서 1개 작성함
UC Davis, Team S11-G4, Lore Fall 2018 UC Davis, Team S11-G4, Lore Fall 2018 회원
UCD-LORE-F18S11G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 450
