주요 콘텐츠로 건너뛰기
Acer Aspire 7741Z-4643 Wireless Card Replacement
필요한 것
  1. Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/2 Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 2/2
    • Begin by unscrewing the four phillips #0 7.5mm screws on the plate on the underside. Remove the plate by lifting up.
  2. Acer Aspire 7741Z-4643 Wireless Card Replacement: 2 단계, 이미지 1/3 Acer Aspire 7741Z-4643 Wireless Card Replacement: 2 단계, 이미지 2/3 Acer Aspire 7741Z-4643 Wireless Card Replacement: 2 단계, 이미지 3/3
    • Unscrew the one phillips #0 4.0mm screw at the top of the card in order for it to be removed.
    • After the screw is removed, slide the card out. Remove connections to the terminals by pulling up on the connection carefully.
결론
Philip Matena
회원 가입일: 10/23/18
95 평판
안내서 1개 작성함
UC Davis, Team S11-G4, Lore Fall 2018 UC Davis, Team S11-G4, Lore Fall 2018 회원
UCD-LORE-F18S11G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 475
